Should I buy this Cobalt
Bass_Waves
I believe this car is a wiring nightmare. It would be easier to get a used harness and throw it in. Make sure every connector is plugged in. Look at the fuse box. Look at the bundle of wires near it.
Bass_Waves
I doubt it. Most likely unplugged connectors. Somebody had an issue. U can try to see if its bad.
SonicStatic
Binghamton, NY
BWv9dCJIQAAwE8G.jpg:large
BWv9Z6pIIAAjZGT.jpg:large
Key on
BWv9kGWIMAAbfHq.jpg:large
BWv9gfxIEAApuCg.jpg:large
Bass_Waves
There is a plug by the firewall. Check that connecter. Unplug it and plug back in fully. Next to fuse box. On firewall
Bass_Waves
Under the hood.
Ecu isn't paired to the motor or your key is not paired. That security light on the dash means it won't crank. So you either news to pair the key or preform a crank relearn.
SonicStatic
Binghamton, NY
This plug?
BWzL1LUCQAARbpG.jpg:large
---------- Post added at 02:54 PM ---------- Previous post was at 02:45 PM ----------
I started retracing what my brother and I did last night and found that the computer wasn't plugged back in. Now the car cranks itself when you turn the key to on and wont run then keep cranking and stopping for about 1 second on 1 second off until i take the key out
Trefaygo
