Should I buy this Cobalt
SonicStatic
Binghamton, NY
The fuse is good and I switch the relay with another one thats the same kind
---------- Post added at 03:24 PM ---------- Previous post was at 03:23 PM ----------
I can hear it priming now
Bass_Waves
Yes that's the plug. Unplug Ur and plug it back in. That controls a few sensors. Like coolant. As for crank no start. At least Ur getting somewhere. The pump not priming could be anything. Look under the fuse box and see if its clean and the harness is not cut.
---------- Post added at 03:36 PM ---------- Previous post was at 03:27 PM ----------
OK. So u tries to crank it so far?
Bonus. Still not starting?
Still have the security light lit? Is the fuel getting to the combustion chamber? You can try priming it multiple times before starting. Are the plugs firing? Plug them in resting against the valve cover to see if they spark.
Is it trying to start in the RUN/ON or START position?
Bass_Waves
Spark and fuel is what u need. If its still not starting. Then security may have tripped on it.
DB00000001
