transfluid
06blackbalt
Az
na im not worried i got no warranty any way 122,500 an still runin strong
06blackbalt
Az
ya i know i read the recall all the do is stick some plastic in there an ship it lol
AAS G5
Plymouth, WI
Recommended Fluids and Lubricants
Fluids and lubricants identified below by name, part number, or specification may be obtained from your dealer.
Usage
Fluid/Lubricant
Engine Oil (2.2L and 2.4L L4 engines)
Engine oil which meets GM Standard GM6094M and displays the American Petroleum Institute (API) Certified for Gasoline Engines starburst symbol. GM Goodwrench® oil meets all the requirements for your vehicle. To determine the proper viscosity for your vehicle's engine, see Engine Oil .
Engine Oil (2.0L L4 Supercharged engine)
The engine requires a special engine oil meeting GM Standard GM4718M. Oils meeting this standard may be identified with the American Petroleum Institute (API) Certified for Gasoline Engines starburst symbol. However, not all synthetic API oils with the starburst symbol will meet this GM standard. You should look for and use only an oil that meets GM Standard GM4718M. GM Goodwrench® oil meets all the requirements for your vehicle. For the proper viscosity, see Engine Oil .
Engine Cooling System
50/50 mixture of clean, drinkable water and use only DEX-COOL® Coolant. See Engine Coolant .
Intercooler System (2.0L L4 Supercharged engine)
Hydraulic Brake System
Delco® Supreme 11 Brake Fluid or equivalent DOT-3 brake fluid.
Hydraulic Clutch System
Windshield Washer
Optikleen Washer Solvent.
Parking Brake Cable Guides
Chassis Lubricant (GM Part No. 12377985, in Canada 88901242) or lubricant meeting requirements of NLGI #2, Category LB or GC-LB.
Manual Transaxle (2.2L and 2.4L L4 engines)
DEXRON®-III Automatic Transmission Fluid. Look for "Approved for the H-Specification" on the label.
Manual Transaxle (2.0L L4 Supercharged engine)
Manual Transmission Fluid (Part No. 21018899).
Automatic Transaxle
DEXRON®-VI Automatic Transmission Fluid.
Key Lock Cylinders
Multi-Purpose Lubricant, Superlube (GM Part No. U.S. 12346241, in Canada 10953474).
Manual Transaxle Shift Linkage
Chassis Lubricant (GM Part No. U.S. 12377985, in Canada 88901242) or lubricant meeting requirements of NLGI #2, Category LB or GC-LB.
Chassis Lubrication
Hood Latch Assembly, Secondary Latch, Pivots, Spring Anchor, and Release Pawl
Lubriplate Lubricant Aerosol (GM Part No. U.S. 12346293, in Canada 992723) or lubricant meeting requirements of NLGI #2, Category LB or GC-LB.
Hood and Door Hinges
Weatherstrip Conditioning
Dielectric Silicone Grease (GM Part No. U.S. 12345579, in Canada 992887).
Nice Post
423
Kilmarnock, VA (USA)
ok i bought a tranny cooler i know ill have to add a little bit of fluid when i install it what type of fluid does it have in it? is it dextron, an im auto btw.
CHECK your Owner's Manual or see your dealer to ask. Early years (M.Y. 2005 and earlier) use Dexron III automatic trans fluid and some later models (2006 M.Y. up) can ONLY use DEXRON VI. You CAN use Dexron VI in ANY GM auto trans,, BUT you MUST use ONLY DEXRON VI in those cars that were factory filled with DEXRON VI fluid!!
GTO 1
Davidwrolo
