makes sense to meHaha, 3mm is a huge difference to the front swaybar. On a solid bar, most of the torsional resistance occurs in the outer portions of the bar. The material in the center of the bar does less and less the closer to center it is.
It's easy to understand, like torque. More leverage as you get further from the fulcrum or pivot point.
annnnnd, because its on the outside, increasing 3mm there is alot more noticable then going say....5mm-8mm as your adding MORE meat for that 3mm
not sure if that made sense
