sway bars
Auburn, WA
Haha, 3mm is a huge difference to the front swaybar. On a solid bar, most of the torsional resistance occurs in the outer portions of the bar. The material in the center of the bar does less and less the closer to center it is.
It's easy to understand, like torque. More leverage as you get further from the fulcrum or pivot point.
makes sense to me
annnnnd, because its on the outside, increasing 3mm there is alot more noticable then going say....5mm-8mm as your adding MORE meat for that 3mm
not sure if that made sense :p
ls1fbody
Well, you're adding it where it counts, but i believe you're trying to say the increase in stiffness relative to the increase in diameter is directly related and exponential.
Tom
Houston TX
OOOO no i did not mean there will be no difference, I just think replacing the rear is more then enough for a daily
ls1fbody
Lol, most SS's are daily's as well. Adding a rear sway bar will do more to effect your DD than the front would.
Tom
Houston TX
i know,but thats not my point lol....My point of the 2, i would just do the rear...why? easier install and its more noticeable then doing the front....
ls1fbody
those are only an upgrade for the FE1 cars, for the FE3 and FE5, they're a downgrade. Not knocking your setup, just saying that for an FE5 car, there would be no reason to look there.
critty84
