Remote start installation help
Twintechsouth
Nc
ive done a remote start on my BALT and id say the ignition wiring was the easiest because i believe there is only like 3 wires u need to connect verify u have the right wire locations on your ignition
Which wires did u use, I have yellow ignition, Brown accessory, white and a white/black
Twintechsouth
Nc
I have those hooked up also,,, the bypass required me to split the wht/ and wht/blk
I have the bypass hooked up according to the xpress pkumux sheet for the gm. With the starter wire from the r/s to the bypass
This is what I got:
Pink r/s ign to car - yellow
Grey r/s acc to car- brown
Brown r/s starter wire to pkumux purple
Split the white wire at ignition
Bypass wht/red to car -wht to green clip
Bypass wht/blk to car - wht to other in
Sorry for the long text...
What bypass are u using?
Do you realize that you're replying to yourself from 3 months ago? ;)
Try messaging gberland, he hasn't been on the forum since 2014 so probably won't see your post.
worknowplaylater8
