po1071 too lean
M-Town,AZ
Not always.Sometimes idle will kick up just a wee bit to where you wont notice.My buddys jeep did that.Then sprayed the intake manifold with carb cleaner and found out the intake manifold gasket was leaking
ionit3
o town fl
ill prolly check all gaskets tomorrow and clean sensors as well as reset with batt
---------- Post added at 05:47 AM ---------- Previous post was at 05:46 AM ----------
i hope it works i hate unnecessary lights and i hate the cel
Jn2
unplug ur battery for a good 15 seconds, will turn the CEL off...always worked for me in thepast i never did it for minutes :p run some seafoam thru it, see if it still does it
ionit3
o town fl
Its make a loud whistling today I almost garuntee one of the seals isn't seated r something
ionit3
o town fl
ug so i didnt remove the manifold this morning just the tb and sensors, idk what to clean sensors with, resetting computer made the light go away but now its back :think:
so tomorrow i guess im gunna take off the whole thing and check every damn gasket idk ug
ionit3
o town fl
ok so tomorrow im gunna try cleaning the tb, the maf, the 02 sensors, anything else i should check? if that dont work im gunna take off whole manifold and replace gaskets, everything seems fine currently other than that code. :-/
ionit3
o town fl
ok so its actually po1071 too lean in bank 1.
only thing i havent done is replaced/cleaned the o2 sesnor
ive cleaned maf, unplugged battery, replaced gaskets, checked couplers, anything else i can do? i think i read check spark plugs somewhere. but not sure
ionit3
o town fl
never changed the fuel filter and idk when i last had a tune up to be honest
worknowplaylater8
