Did you check the fuel pump fuse and relay and have 12 VDC through both ? Did you check to see if you are getting 12 VDC to the connector at the fuel pump ?
If you have troubleshot the problem and can say yes to all the above, the next step is to undo the fuel line at the pump and see if fuel comes out at the proper pressure.
