Need help installing an amp
newfiedan
SK, Canada
Yes you can run the tweets off the factory deck but for best sound you will want to amplify them. It is possible to do the 5 channels but to get the most out of it you will want 2 line output converters 1 for the front L and R and 1 for the rear L ans R. That will give you the best sound out of the setup. If I were you I would run it with the amplifier. and LOC does mean line output converter.
emperorjj1
Salem, OR
if you have components u need to use the crossovers. they should only have one input for off the deck.... a tweeter realistically uses so little power its amazing most of it is wasted in the crossover
worknowplaylater8
