Need help installing a headunit in an 08 cobalt
newfiedan
SK, Canada
I like the car overall, mind you. The ecotec was the first decent move that gm made for some time engine wise. I drive a 96 mazda mx3 v6 but I do like a blacked out cobalt with a nice tasteful set of chrome rims. No bodykit or wing. Just found this off the cobalt SS site.
Is there another solution other then the pricy gm lan harnesses for 07+ vehicles?
Yes you can buy the regular harness that will plug in but you will loose your door chimes.
Metra = 70-2202
Scoshe =
American International =
Bluewave =
Jn2
cheapo harness=lose your chime when the door is open, keys are in the car, when u use your turn signals, pretty much everything yoru car would chime for
expensive harness= everything still works, chimes and all
this started in 07, in 07 they made the chimes from from the speakers vs the cluster i believe is where it comes from on mine
newfiedan
SK, Canada
from what I can tell from my research so far you don't loose the turn signals with the deck removed or cheapo harness just the door chimes and onstar capability which he does not have anyhow.
Easy enough to find out, pull the plug on the stock head unit and figure out what doesnt work any more.
dman090
Huntington TX
ok im pretty knowledgeable in this feild.... so heres my 2 cents..
you can get the cheap harness:Metra 70-2202
pretty much anything in the car that "dings" is gonna go bye bye, i am using this harness my self and i LOVE not having annoying door chimes or blinker noises :)
OR
you can retain all that chimes shit using the : Metra GMOS-LAN-03( not really worth it IMO)
then your gonna need a antenna adapter :Metra 40-CR10
and to answer the mix up
05-06 cobalts the door chimes were in the gauge cluster
07-present cobalts, the door chimes came through the speakers
need anything else, just ask :)
DaveBlank
Beckley, Wv
I think I could live without my seat belt chime, forgot you keys chime, what about your lights chime...but i kinda listen for the turn signal...
dman090
Huntington TX
the lights chime? like if you leave your lights on when you turn the car off? it goes away too. every little "ding ding" goes away with the cehap metra harness
Turn signal click too I assume. Would be wierd for me not hearin it lol
dman090
Huntington TX
yah the turn signal click gets lost too, i didnt like it at first, but i listen to my music so loud i dont realize its gone!
pstaus
