Low Oil pressure
Auburn, WA
mine is other way around, it starts off high and as the oil heats up and thins out it gets lower
someone else suggested its cause im cammed and ttr mounts and it vibes enough to screw with the spring in the electrical sender (already checked all the electrics)
outtamymind
Calgary, Alberta
ya those suggestions are a little out of my expertise range so i don't want to really comment on it. but how many miles on your car?
outtamymind
Calgary, Alberta
crankcase cleaner will usually do the trick. and alot can happen in 5k. but start off with the things i suggested above and we can go from there and maybe some of the other guys on here can chime in with some suggestions in the morning. but i'm out i need to sleep.
M-Town,AZ
Its your fuel map...Thats why your unloading in 3rd(I told you it was 3rd) Ill tune your NOS down and youll run 9's. :)
sorry
Fwagile
