How Do I Get Rid of My VHT and Clear on my Tails
Where the heck have you been?
PS Thanks for the link. After doing this, will it leave my lights all cloudy? Or will it look like factory or close to it?
Pretty sure it's gonna be cloudy after you use that but if you grab a headlight restorer kit or plastic polish you should be able to get to a better than stock finish.
ionit3
o town fl
exactly you can use the 3m, ive personally sanded and repolished then used headlight cleaner kit. worked amazing.
wardzach2007
Houston, Texas
Awesome. So you've actually done this with my same problem? If so, the exact same process will work wonders and should have no problems?
The only reason why I'm anal about this is because this is as of now my only set. If I screw up, I have to drive it like that until I get some cash to get some more from Ebay.
