hid
outtamymind
Calgary, Alberta
cobaltcpe yours is a single filement kit then and you do not have highs. huckernage i'm not sure on yours but i will keep thinking. other then going back over everything and making double checking you got everything connected properly.
When I did mine there was a wire sticking off the high beam side that you hook up your halogen highs to, its a single beam system. huck, it sounds like something in your wiring is hooked up wrong, or you have a single filament system. Leaning towards single cause that bulb looks exactly the same as mine.
---------- Post added at 11:27 PM ---------- Previous post was at 11:26 PM ----------
Quick Q, how many wires are going into the back of your HID bulb? That'll tell you if its a single or dual. 2 wires=single 3=dual
huckernage
quebec city
i have one bulb doing high and low.
from the bulbs, there is one to plug with the ballast and the other 2 on that:
you can see the picture of a bixenon bulbs. same of mine:
http://cgi.ebay.ca/2-HID-BiXenon-Bu...r_Truck_Parts_Accessories?hash=item45f06f6a4c
ionit3
o town fl
alot of times the 9004 and 9007 kits when shipped are mixed up u have to switch two wires and it fixes the issue
worknowplaylater8
