help, strange idle
1WhiteSSTC
Banned
The Great White North
Nate, it's due to moisture
the + temps then - temps are causing moisture to get stuck on the maf sensor
I had the same problem a few weeks ago, i cleaned up the intake, the tb and cleaned the sensor... the problems been gone for 6 weeks now.
okie dokie, will have the sensor cleaned, dunno about how easy it is to get at my TB tho, it's sorta burried......
parise9
Yardville, NJ
i had the misfire issue.. they said let it hit 140-160F before pushing it. i changed to denso plugs .40 gap and haven't had the issue since... but the sputtering..no idea..
mine does the same from time to time when it's cold and/or rainy. mine also some times gets to the point where it sounds like i am cammed.
worknowplaylater8
