fuel injector cleaner or fuel system cleaner
Cobalt_TC
Raeford, NC / Dahlonega, GA
Guess what? We don't know because there are literally hundreds of possibilities.
Hook a DTC reader up to it and then report back with the codes.
And in case you didn't know, pretty much any Auto Zone or Advance Auto can/will read your codes for you. Write down the number and then post it here (Example: P0420)
Advanced Auto Parts will be able to tell you your code and clear it for you if its nothing serious. When my IC coupler popped off my CEL for the MAF sensor came on and they cleared it.
CJ n Shagy
NW Dallas, TX
Sea Foam | How to Use Sea Foam Motor Treatment
i have been using Sea Foam for 43 years now and still the only one i use. it has been in my daughters cobalt since 3000 miles and my HHR since 3000 and i have 96000 on it
every oil change i put in 16 oz in the next fuel up and 8 oz in the oil.
sea foam is great w gas, diesel and even w 2 cycle oil in lawn and boats. i use it in the lawn mower at the beginning of the year
best at getting rid of water in your system too
if you havent cleaned your injectors then i would run 3 cans in a row in the next 3 tanks of gasoline.
great in motorcycles too
ive use it as a carb soak and cleaner too.
been around for years and proven over and over
