fastest n/a 2.2
huckernage
quebec city
tom wont toast me until he understand DC and WR
he already has issue with traction. and he actually has 180whp prouved
I beat civic b20 Turbo due to his traction situation.
you can have xwhp , if you are not able to distribute that power on the ground for me it nothing.¸
it not the most expensive built 3000k can. but maybe the most optimized one.
DC= drag coefficent
WR= weight reduction
---------- Post added at 06:24 PM ---------- Previous post was at 06:12 PM ----------
i just need to learn to drive like you, then itll be over ;)
just wait till after winter, should be pushing 260ish whp and have lightweight flywheel and new clutch and axels with some nice tires....
then your toast again ;)
oh, and ill still be n/a :D
dont spend a $ for it. my friend has cavalier 04 that run 11,25 with stock axle. spend your money somewhere else. buy a wingless trunk before that and you will have for your money
about your flywheel, alt. and crank you lost big tq and win honest hp on high rpm
that is rotation part
speak about moving part as a retainer and a seat. there is big imporvement to get these lighter in order to get 8000rpm
Auburn, WA
im getting a full si valve train installed which will let me rev out higher
about w/r - im running a full car, once i get lower times ill pull out the interior, but i will never cut up my car, that kind of defies the point as a whole.
as for wingless trunk, when i start looking for SMALL amnts of an increase then ill just pull off the wing and put it back on afterwards...but the things like this (wr and dc) will only gain you a LITTLE bit in the long run, i have to get the driving itself down first, and get good, then take those into accnt to get the best. until then its just a waste of time to pull it out every time
huckernage
quebec city
i ve a 2,25'' custom cat back not mendrel crush
it your call.
there are very nice downpipe sold on this site.
a lsj header is enough
siccracingturtle
it your call.
a lsj header is often
well i have obx 2.4ss header d/p combo. just wanted to make sure my exhaust wasnt choaking up my car
