Clunking in rear
Jaws4God
My wife and I noticed a clunking sound from the back left of the car... When I sat in back seat it sounded like it was coming from in fender well... I pulled the tire off last night and pulled out the fender well plastic and could see anything that could be making good the noise.. anyone have any ideas?
It sounds a lot like as if we left the trunk barely latched and it's banging together...
Jaws4God
Shock bolts tight?
I checked them.. seemed good.. is it possible it's the bump stops? I can try to record the sound since it's fairly loud and frequent since it is related to bumps in the road..
Thank you guys for always being willing to help me.
I have a persistent squeak in the rear when the car is loaded, might be the stops.
Trailing bushings from the rear beam?
Tug on the wheel back and forth.
Its the rod that connects to the body from rear axle bar
Jaws4God
Here is a picture of the underside. . Where did you say it could be coming from?
I also recorded the sound.. you can hear it almost every time I hit a bump...
https://www.dropbox.com/s/g0j8hho07ma0u0x/Clunking rear left.m4a
Thanks !!
It's at the front of the rear axle. Where the swing arm connects to the body. More or less right in front of the rear tire.
Mscanlan
