Audio guys- Help me install my new amp!!
dunit121
vero beach
Ok, so, how do I take the remote wire and hook it up to the back of the head unit?
Do I need any connectors? or does it just go straight into the head unit?
you just extend the wire to the wiring harnest. i would recomend using a connector but electrical tape will due. you just take the blue remote wire extend it and run it then connect it to the remote wiring coming out of the wiring harnest
mrsilent13
Moreno Valley, Ca
gCobalt05
North GA
cool...well it should be a very easy swap...but try not to mount it to the box again...mount it behind the back seat...this way if you ever want to take the box out you dont have to disconnect the amp to remove the speaker box.
Ok, thats what I was thinking about doing.
What tools/ parts do I need to be able to hook it up to the back of the seat?
mrsilent13
Moreno Valley, Ca
well the amp should have some brackets on it...so all you need are some screws...maybe some spacers to give the amp some clearance from the back of the seat and a screw driver or drill
gCobalt05
North GA
Big help man. Thanks!
I can probably just use the screws that were in the sub dont ya think?
REDLINE
louisiana
if this was my car i would run the blue wire(remote turn on)to the harness of the radio. looks so much cleaner and well done. i would not put the amp back on the box. doing that could/will hurt your amp. when it hits the wood flexes making the amp do the same. thats not good for the boards in the amp.
dunit121
vero beach
ur so intelegent... u have no idea how many people ive told that too but they do it anyways ... and then 6 months later there like wtf i need a new amp allrdy
I've been running 2 12" Pioneer Premier's with a 1k amp strapped to the back for over a year and a half now and haven't had a problem.
gCobalt05
North GA
Ok, and how do I go about taking the remote wire and hooking it up to back of Alpine head unit?
worknowplaylater8
