How To: rear springs
Thought you had a modified one...or is it just the weld in bar thats different?
ls1fbody
It is modified, i just wanted to test you and see if you could tell the differences from the pictures haha
ls1fbody
There is an adjustable sway bar inside the stock one, you can see the bolt on the closest trailing arm that acts as an anchor for the adjustment portion on the other side. It allows me to add a left or right preload. Also, the whole thing is modified to lower ride height 1". It has spherical body mounts instead of the squishy stock rubber bushings, and revised shock mounts. If i had the coin i could run a true coilover setup in the rear.
I'd love the spherical body mounts and revised shock mounts lol.
ls1fbody
the shock mounts do nothing for the separate spring and shock setup, but the clearance to run a coilover there is the true gold.
Haven't been able to test the rear yet, but according to Powell it keeps the roll center from shifting which is good for high speed stability and weight transfer.
