How To: rear springs
sundevil07
Phoenix AZ
have any pics of the car settled in the rear? these ssc springs make me cringe at the gap in the rear
ford sucks
dearborn,mi
this has the progress springs
ff_drift_lol
long island, new york
that looks uh...how do i say this in a nice way...terrible lol. mine were way nicer than that. the fronts are so high on that car.
old pic
ls1fbody
Top bolt - 66 lb/ft
Bottom bolt - 81 lb/ft
Be careful when re-installing the lower shock bolt, it's fairly easy to cross thread if there are any loads.
Also, it is not recommended to use the pinch seam for anytheing except the stock jack. it's do-able, but i don't recommend it. Also, if you are using the rear TWB for a jack point, use a 2by4 to spread the weight evenly across both edges of the beam.
Images uploading. Otherwise, good how to. Also, i use an old cross-tip screwdriver to align the top shock if i have removed the bolt.
