What's the difference between a lt and rs suspension?
Jaws4God
2009-2010 is the same exact thing. You said you have a LT? You have fe1
My redline has fe3 and I can def tell you it is diff and sucks next to my fe5.
The fe5 is pretty much the SS only type of suspension. Doesn't mean u can't run it
If u notice in the upper section. When half cent says all 2008+ are fe5. He was talking about the LNF or SS/Tc .
Oh ok thanks. I was hoping I was reading that wrong. And it's nice to know that the 2009 is same as 2010.
Do you know why when I bring up the 2010 LT on autozone or advance auto it says it's a fe5?
Cuz they suck. That's why I said use a 2007 SS. 05-06 is diff
Jaws4God
I think I understand what you are saying.. so ill make sure to ask for 07 SS
Do I need to swap out the sway bar as well to do it correctly or should just the end links work? (And hopefully fix the turn clunking :) )
Thank you for the information and patience.. If you all are ever in the area.. beers on me!
Try the end links first. If that does it then ur good to go. If not. Then seel out a sway bar. They ain't expensive.
I could have sworn the front bar was larger on the LNF. Could be wrong, but I'm pretty sure. I measured it a few months back and posted it online.
I say go aftermarket like Moog for the end links. They're cheap enough.
Haha I told u before. The lnf has the same sway bar. There are freaks from factory than came with a 24+mm sway bar. Some 24.5
John Powell confirmed that.
I recall the conversation now that you mention it, though I don't recall my findings. My memory's going already.
Jaws4God
Where is the best place to buy these from? Any chance I would get them by weekend?
__________UPDATE____________________________
Well I went ahead and ordered these from Amazon.. should arrive on Saturday... Hope they are the right ones for my suspension..
Moog K750012 Sway Bar Link Kit
incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces, 9.86" length center to center, (RPO code FE5)
Mscanlan
