If its fender. embrace it cuz its going bye bye. Not bad honestly . 90% of lowered ppl eliminate them. Including myself.
I wonder. Go in and check them. Just pull on em. If they come out then they lose.
So you pull out the inner plastic fender? How hard are they to remove?
I can try to pull on them and see if they are loose.
I hope you all know how thankful I am for your help. It means a lot.
Sent from my SGH-M919 using Tapatalk 2
---------- Post added at 12:37 PM ---------- Previous post was at 12:34 PM ----------
If you can accelerate, your axle is still in the transmission.
I never had any rubbing issues with my Sportline springs but you can check if it's the fender by ensuring the tire shoulder and fender lip are clean and dry. Apply a small glop 1/8" high of petroleum jelly or similar substance to the inside of the fender where it might possibly rub, take it for a short drive and get it to make that noise. Check the tire for petroleum jelly smudges and then check how much is gone. Could probably do that with masking tape as well by affixing it to the tire.
Post some pictures too.
Yes. It seems to accelerate fine. Only notice grinding when turning.
I see what you are saying about the jelly.. to make it visible where it may be rubbing.
I'm not sure what you mean about the tape.. that may be easier cuz I don't have any jelly..
What would be some good pictures to take that would help you all see what may be the issue?
I also want to thank you for taking this time to help me. It means a lot to me since I don't really have any car friends in this area that can help me.
