What is the best lower spring out there?
Punk
i was going to get them but didint have enough money
Aikidoshadow
Las Cruces, NM (aka BFE)
best as in what performance, ride, drop, sitting level?
pedders makes the best performing spring we have currently.
They drop somewhere in between sportlines and a pro kit and keep the rake stance we have OEM from what I understand.
07cobaltsssc
Woodbury, MN
So basically i just should save up the money and drop the car on coilovers because with all the other components i need to have. Alright if I went with some coilovers what brand should i get and then do i need to get these other parts that you guys said that i should get??
If you get coilovers you will still want to buy rack spacers and rotated transmission mounts.
07cobaltsssc
Woodbury, MN
Ah alright. What is best brand of coilovers for the car?? What if i dont get the rack spacers and the rotated transmission mounts what will be affected?? Sorry for all the questions i just want to understand this
Coilovers all depend on your budget, you get what you pay for. If you're cheap, you get cheap crap. Spend the dough and get the good stuff.
Rack spacers will reduce bump steer, which will increase the lower you drop the car.
Rotated transmission mounts crank the engine forward a bit so that the axles are lined up correctly as to avoid breaking your CV joints as often.
Also after you lower your car get an alignment done. I've been lazy and haven't gotten one yet.
dman090
Huntington TX
hmmmm maybe thats my problem... do they have a set for the 2.2 automatic trans?
Havent seen a set specific to the autos, but you could probably get the rear spacer from OTTP if you called them and put it under your auto mount, would rotate it a bit.
hessjacob33
