USMCFieldMP
Posted here by request. Th initial build is done... but now I'm starting to upgrade everything, since I got quite the large pay increase this year.
Here's how it started:
01/30/2009 - Started tearing the SS apart tonight.
Started by removing the front bumper, intake, S/C, Alternator, Intake Manifold, I/C Pump, and stock heat exchanger. Then I moved on to the exhaust side of
the car. I removed the downpipe, but then got held up trying to remove the cat-back, since all the clamps seem to be rusted tight and it won't pull apart.
I was hungry, so I called it a night.
I'm wanting to route my intercooler piping around the engine... so that I don't have pipes going over the engine, etc. But I'm not exactly sure how to do
it. Looking at it from under the car, it looks like it would be a tiiiiiight squeeze.
Last night I bought a Precision SCM-5031E (450hp capable 50 Trim w/ DSM Style Hotside), a DSM Style O2 Housing, 60# Injectors, and an LS4 Throttle Body.
In the next few days I'll be picking out/up an HKS SSQ BOV, an intercooler, intercooler piping, and my Oil Lines/Fittings. Gonna order the Vulcan Intake
Manifold and Vulcan Long-Tube Turbo Manifold from OTTP. I'm debating on how to run my exhaust. I don't wanna have all the twists and turns that the stock
cat-back runs, so I think that I am just going to shoot it straight back, do the first 90* turn, and then have it exit in front of the Rear Tire. I'll
probably throw a big resonator in there to quite it down a little. Open to suggestions on the cat-back though.
01/31/2009 - Started by taking MAP Gas to the cat-back. After a couple of heat sessions, it came apart nice and easy. Then dropped the rear bar
to remove the springs and took out the front struts. Taking the front struts apart was giving us a hell of a time, so I moved on to misc shit on the car.
I removed the factory boost controller, then removed all of the hose for the PCV System. I then moved onto the Exhaust Manifold, which was pretty simple,
until I forgot about that one lonely bolt all the way down past Cylinder #4. But it only took me about 2 minutes to realize that something was still
holding it on. Haha. Went to put the Boost Gauge/Pillar back in the car, but it looks like the tiny little ball piece that slides on the end of the vacuum
line in the gauge is MIA... so I'll either have to come back and find it later, or just buy a new piece.
That's it for tonight.
Looks like I need new Sway Bar Links. The boot on this one got fucked, looks like both sides are toast actually.
I wiped the inside out with a napkin a little bit and the shine of the port started coming out again.
02/04/2009 - This just arrived...
02/11/2009
Waaaaaaaay too short... Doesn't fill up the mouth at all. For some reason, when I ordered it... I thought that 27" was gonna be A LOT
bigger.
HORRIBLE PowderCoating job... but it was free... and it doesn't look that bad on the front unless you look really closely. The back lips are
appalling.
You'll notice he didn't get the inside the Lug Nut area very good.
Look closely... you'll see it.
02/13/2009 - 2.2 Alt and Tensioner showed up, along with my HKS SSQV and 60# Injectors.
Still need to order Oil Lines and Manifolds. Hallman Pro Boost Controller
I need to find a connector/pigtail for the 2.2L Alt still though...
02/11/2009
bigger.
appalling.
