USMCFieldMP
Name
Robert - USMCFieldMP
Findlay, Ohio
Car Info
2005 Victory Red Chevrolet Cobalt SS
Modifications
-Vulcan Tubular Equal Length Turbo Manifold
-Vulcan Short Runner Intake Manifold
-Custom Welded Downpipe w/ Wastegate recirculated (Started life as a ZZP Downpipe)
-Precision SCM-5031E (50 Trim Compressor - .63 A/R Ratio - 76 Trim Turbine)
-Tial Blow-Off Valve
-Godspeed 38mm Wastegate
-27x6x3 FMIC (Painted Black)
-Hallman Pro MBC
-Autometer ES Series Mechanical Boost Gauge
-Autometer ES Series Wideband
-Aftermarket Quaife LSD
-SS/TC Shocks & Struts w/ Pedders Springs
-OTTP Stg2 Rotated Mounts
-N2MB WOT Box
-Powerslot Slotted Rotors w/ Hawk Pads
-Hoosier Drag Radials
-WickedSS2005's Tune
-Powdercoat wheels black
Not Installed Yet
-Exedy Hypersingle Clutch
-OTTP Steering Rack Spacers
-80# Injectors
-OTTP Return Style Fuel System
-GMPP Adjustable Cam Gears
Pushing 12psi now for the winter months. Bumping it up to 22psi or so once it warms up.
Future plans
Just cleaning up everything that I threw together last May and finishing the car off.
-ZZP Triple Gauge Pillar w/ Autometer ES Series EGT and Oil Pressure Gauges
-OTTP 1" Rear Bar
-Powergrid Sway Bar End Links
-Aeroforce Interceptor (Black Face, Black Bezel, Red Lighting)
-Bullseye Power S256 Extended Tip (49 Trim Compressor - .55 A/R Ratio - 75 Trim Turbine) (Will be bought before February 1st)
Findlay, Ohio
Car Info
Modifications
-Hallman Pro MBC
-N2MB WOT Box
Not Installed Yet
-80# Injectors
Future plans
-OTTP 1" Rear Bar
