Steering shakes
donnkesterjr
Macon, GA
At high speeds, I've noticed that when I depress the brake pedal (not fully, but partially, like in controlling speeds), the steering wheel shakes like crazy. It's less noticible at only 50, and under 45, it is not there at all.
I've already checked the brakes, and they seem fine. I'm starting to wonder if it's the steering rack & associated parts. What's the best way to check the rack & tie rod ends for damage/wear?
donnkesterjr
Macon, GA
They must be very mildly faded, because they passed the eye test. Oh well. At least it's a cheaper fix. I'll actually take them off the vehicle & give them a more thorough check this weekend.
You usually can't see warp until it's real bad, take them to Napa, they can usually mic them and tell you if they are warped. They can also take a little off to resurface them.
It has to be disc warp btw, speed makes it worse under braking. Loose caliper bracket bolts could do that as well but real unlikely. Have you changed discs or pads recently?
donnkesterjr
Macon, GA
I didn't change the pads until AFTER all this started. I noticed a slight uneven pad wear on the driver's side pads, so I eyeballed the rotors & the brake lines on that side, and it all looked OK. I also hadn't noticed a degredation in braking ability either, so that's why I was thinking it was a steering issue.
Like I said, you're not going to be able to eyeball a 45-50mph braking warp.
BankDude
just replace the rotors, they're like 30 bucks. don't be a cheap ass
BankDude
whenever you do a brake job, it's always recommended to replace the rotors. just remember that. for the small amount they are to buy, it's worth the money
Or at least resurface them. If you go with new ones buy only OEM blanks, anything else is going to warp easier.
ChronoPulseX
