Should I buy this Cobalt
SonicStatic
Binghamton, NY
When it cranks it doesn't even try to run. the guy gave me some sensors that he changed but I have no idea what they are or where they go.
---------- Post added at 07:20 PM ---------- Previous post was at 07:15 PM ----------
BW0KETLCAAAK9ag.jpg:large
BW0KSKSCQAI81Is.jpg:large
BW0KWFsIIAAQraK.jpg:large
BW0KpfGIYAAGztw.jpg:large
Bass_Waves
Crank. Cam.oil pressure maybe. Absolute pressure sensor?
Bottom 2 are cam and crank
---------- Post added at 07:23 PM ---------- Previous post was at 07:21 PM ----------
Soooooo from Whitby are saying. Its not getting air????? Check the intake throttle valve. Take off the inlet to it and see if it will crank over without restriction
SonicStatic
Binghamton, NY
The black plastic on connecting the TB to the air filter? On or off it does the same
Bass_Waves
It is an electrical issue because previous owner hacked it over fixing it right. It has codes stored. Be great to pull em.
Bass_Waves
Try to burn off everything inside the cylinder. Then put the injectors back in. Plugs may be wet
Bass_Waves
Crank. Let the plugs spark and it will start to burn off. When its dry enough. Put the injectors in. Also pull the fuel pump fuse so it doesn't make a mess while Ur cranking it.
ChronoPulseX
