Removing Emblems?? I need help
reyesa21
Valparaiso, IN
So i just got a cobalt lt about 2 months ago and i want to take off the cobalt lt and the dealership logos off. any help on to how to take it off safely without damaging paint. im most likely going to keep on the bowties but everything else im taking off. anny help???
Intmd83r
New Hampshire
the cobalt shit take 10 lb fishing line put behind it and slide it behind it . the dealer stuff you can take hotwater and a debitcard or something like that and kinda peel it off . if you can get a hair dryer out to heat all the stuff up a little it comes off easy
YouDriver
Nazareth PA
Also you can use a heat gun VERY lightly, heat it from the other side of the metal if possible or the edges of the emblem and the adhesive should peel off. DO NOT LEAVE THE HEAT GUN ON THE SAME SPOT make a circle with the gun or something just dont heat one area. If you really dont know what your doing i wouldnt reccomend this strategy
reyesa21
Valparaiso, IN
Alright ill try that. I dnt hav a heat gun so ill jus use the hair dryer. How do I get that adhesive sht off. Goo gone or something like that?
reyesa21
Valparaiso, IN
i used floss and went up and down with it and then i pealed as much as possible of the foamy shit off and then used goof off and rubbed it off, looks veryy clean now.
critty84
