cant take credit
Here's how I painted my dash pieces, sorry I didn't take pictures during the process but it's not really essential for this how-to. These are just my reccommendations for the process, based on what I did.
Your results will be dependent upon your prep work, patience, and the area in which you are painting. I used a home-made spray booth with heat and ventilation that was made of plastic painters drop coverings and is close to dust-free.
You will need:
1.) Rustoleum (or other) Plastic Primer.
2.) DupliColor Cherry Red (or other color) Enamel. **Please see below.
3.) DupliColor Clear Enamel. **Please see below.
4.) DupliColor Prep Wipes (or mild soap and water or tack cloth).
5.) 300-400 grit sand paper.
6.) 600-800 grit sand paper.
Optional:
7.) 1000 grit sand paper.
8.) Fine cut rubbing compound or your favorite polish.
9.) Car wax.
Instructions:
1.) Scuff the pieces you want to paint with a grey 3M scuff pad or 300-400 grit sand paper.
2.) Use a DupliColor Prep Wipe to wipe off all the dust and junk that the scuffing creates.
3.) Spray one light coat of plastic primer, let dry 10 minutes.
4.) Spray one slightly heavier coat of plastic primer, filling in the light spots from the last coat, let dry 15-20 minutes.
5.) Sand with 600-800 grit if needed.
6.) Use a DupliColor Prep Wipe to wipe off all the dust and junk that the sanding creates.
7.) Spray one very light coat of color, let dry 10 minutes.
8.) Repeat Step #7 three more times.
9.) Spray one medium coat of color being careful not to let it create runs, let dry 30 minutes.
10.) Spray one light coat of clear, let dry 10 minutes.
11.) Repeat step #10 two more times.
12.) Spray one medium coat of clear, let dry 6-8 hours before re-installing.
Optional:
Requires 24-48 hours dry time, depending on environment.
13.) Wet sand with 1000 grit paper.
14.) Buff with fine cut rubbing compound or your favorite polish until the surface becomes perfectly smooth.
15.) Wax.
**Please note, if you are using enamel paint, you will need enamel clear. If you are using lacquer paint, you will need lacquer clear. DO NOT MIX ENAMEL AND LACQUER PAINT. If you mix lacquer and enamel, the paint thins out, just as if you applied thinner directly to your piece.
End result:
You will need:
Optional:
9.) Car wax.
Instructions:
Optional:
15.) Wax.
End result:
