onedoughboy
So you have a 2006 Cobalt 2.2l with 57k, with a miss on 1 & 3, you changed plugs, you swapped injectors, you replaced the coil pack, and verified compression.
How long have you owned it? When did it start missing?
Was the coil pack new or used. Could be two bad ones, seems not likely. There is a ground wire on the transmission about level with the starter, on a bell housing bolt, that is known to become corroded, but the miss fire would be random.
