lowering help
KLRtuner
take each spring out 1 at a time, set yourself up a jig and put your spring in the vice. Apply ample amounts of heat via oxy/acetalyne torch.
As you heat the spring turn the vice in to compress the spring. then let it cool for 3 minutes, and drop it into a bucket of water. This keeps the spring from returning to its original shap.
In the end you have a lowerd car. no money spend on springs, and you didnt even have to cut them.
I'll let the guys that do this kinda stuff chime in, but for the general populace that's not a viable or safe option.
Cobaltpunk
Indiana
Patty, I think your talking about the bump stops. When you get lower springs your supposed to trim them. somewhere between 1.5-4 cm
Aikidoshadow
Las Cruces, NM (aka BFE)
Get some Eibachs drop the car and be done with it.
Please don't cut your springs, its tacky unless its done with extreme experience and scrutiny which 90% of the people who mod cars don't have. Otherwise it just makes an econobox feel more like one.
Bqueen84
