Lock/Unlock Switches
Nate101
I drive a 2005 chevy cobalt (sedan), and recently the power locks would rapidly unlock...never lock unless of course i pressed the lock button. I tried everything, putting the key fob else where and manually locking the car, didnt work. Basically I ended up just disconnecting one switch (the driver side door), and it seemed to stop happening as often, but then I saw it still randomly happened, not every like 5 minutes as before but every couple hours, so I disconnected the passenger door. This seemed to fix the problem
Now my question is, could it be the switches or the wires that is the problem? If its the switches where could I buy 2 new cheap ones?
original post date was back in 2010 he may not answer but how many miles on the car if it still under warranty take it to a dealer
Intmd83r
New Hampshire
i had problem in wifes coupe .... replace switch and it stopped . didnt even have to take door panel off . just pull up on the plastic door handle and you can switch it out easy
yellow_V
haha damnit.. read faill.. forgot to check the post date. thanks
Bqueen84
