Hello,
I wrapped my middle pieces of my door panels in leather with my katzskin kit and was having problems with the center piece. I first mounted it back with glue-gun glue but it never held up and the heat was melting it. So this weekend i decided to finish and redo it a better way. So i went to home depot and got some 1/4"-20 x 3/4" flat bolts and 1/4" washers. Also picked up some Loctite 2 part epoxy that will hold up to 120 degrees. I did use my dremel to remove the plastic mounts and to scuff up the plastic on the inside door panel where i was mounting the screws to. I like this method as i can also unscrew the nut to pull off the center piece if i ever wanted to change it up. It is so solid now then it ever was. I just wanted to post this to anyone else who is having problems with mounting it back. This way takes a little more time but i think it pays off. I hope you enjoy.
