How to install Cams (2.2 but works for any)
mrsilent13
Moreno Valley, Ca
It's slightly confuddling but the last 2 paragraphs tell you exactly how to time it. Minus the chain tensioner.....
TOM!!! Fix it....:lol:
i did my timing with these instructions the first time...since then ive done the timing on these engines a few times where i dont even need the instructions anymore...i also figuered out a way to do the timing without removing the front cover...but its a bit tricky because you need to mark the chain and the cam gears and make sure you put them back exactly the way you pulled them off...or else you will bend something
rockSTAR_SS
I'm going to give it a try. Hopefully I can do it. I've never messed with timing on any vehicle before.
mrsilent13
Moreno Valley, Ca
its not too hard...just follow the instructions carefully and make sure you have a tool to pull the tensioner out......i used a humongous crescent wrench. once you break the torque on that bolt it will spin out freely by hand. and when you putting everything back together try to get the #1 cylinder at Top Dead Center (TDC) will make things a bit easier when installing the chain drive gear. this way the Dot on the chain drive is facing to 5 o clock and all you have to do is install the chain as is without having to turn the crank to line up the dots.
this is very important, the crank turns clockwise....UNDER NO CIRCUMSTANCES WILL YOU TURN THE CRANK COUNTER CLOCKWISE. if you have the chain installed and you turn the crank counter clockwise...the chain will jump and u will damage some valves. so just follow the instructions...good luck
huckernage
quebec city
i got my stg 2 cam
and I have a jtool
will be easier with this tool
what type of lub did you use to lub my cams
is a break it over 30 min. at 2000-2500 is ok
lovely09
Very helpful post.I have my chevy for three years but honestly saying,i have a lot more things to learn including cam installation.I will work on to it.Many thanks.
camopaint0707
NY
mrsilent13-you have installed cams on an 07?? is there anyway to take cams from an LSJ and put them on? or would that not even make a difference
Omgerin91
