wardzach2007
Do you leave the car in gear? Or just leave it in neutral and pull the handbrake?
Or do you leave it in gear and pull the handbrake?
you are supposed to park either in reverse or first depending if the car is facing up or down a hill with the parking brake on.
but, I just park in neutral with parking brake on.
yes, i believe it's the gear opposite. It causes more "drag" in the trans to hold the car in the event brake fails. but parking on a flat surface even a crappy parking brake will hold. if you want more technical i can explain further.
I just leave it in gear, but if I'm on an incline, in gear and Ebrake.
