Tasana
- Joined
- Aug 8, 2013
- Posts
- 7
- Reaction score
- 0
Bass_Waves sent another one, I got it today. He taped the box up real good. For some reason when I seen the harness I almost got emotional. I am going to install it later today. The water has returned to the inside of the headlight housing. So I had an idea. When I remove the headlight housing to replace the harness I am going to drill a tiny hole in the lowest most part of the underside to allow the water to exit and allow air to exit as well from the entry point, creating circulation. In theory this should allow the headlight housing to drain, and then dry out. By drilling in the lowest most part on the underside, there is no access for more water to enter.
I will keep you updated.
And a super thanks Bass_Waves. I will post and text later if the harness worked.
