H.I.D help!!
lebUNIT
edmonton AB
Hi guys, im tryin to install an HID kit on my cobalt and i just realized the battery is in the trunk! How is that guna happen? :think: The wires arent long enough to go there!
Any help will be appreciated
Thanks guys
wardzach2007
Houston, Texas
What kind of kit do you have?
They should just be plug and play. They have a connector to connect to your old wires.
Tom
Houston TX
post pics of your kit, they should be plug and play
i just wired mine into the positive pole in hte fuse box and grounded it to a screw underneth the headlight
Thats kinda how I ran mine, my ground was the little bolt next to the windshield washer fluid.
i dont know if thats where mine is or not, all i know its grounded to a little screw that is right in your face when you take the black mounting thing off for the headlight :rofl:
then i have my ballast mounted right above that lil bolt
The bolt mine was grounded on was directly visable and on the inside of the engine compartment (not out by the headlight)
My ballasts were mounted to the underside of the black plastic headlight mount. Worked very nice.
did you mount your ballast directly to the headlight mount? or under neath on the body of the car? i have mine underneath on the body
Bqueen84
