Here's what I found in the DIC information section.
Unsure of it's equation for "fuel consumption" I'll try looking it up later.
The sender is in the tank. What kind if mileage are you getting per tank? The fuel level gauge is notorious for dropping right after start, on a freeway drive if I flip the ignition it will show up to 1/4th higher than before.
I just filled up and reset odometer to get my milage. will report back.
But with a faulty indication, it'll be hard to tell when I'm near zero. I suspect I should get at least 600 KM (375 Mi) from1 tank?
So is there a fix fro these gauges or just keep replacing? Aftermarket?
Whats the tank size in a LS?
Unfortunatley, the last owner lost the owner manual. So I don't even have basic info.![]()
What differences are you looking for?
