Deuce's 2.4 sleeper?? turbo build
the main purpose i bought this car was to boost. i wanted to sc previously but after seeing wut zzp did with this car it changed. end goal is to run high 11s with it on drag radials. and possibly have up to 500 whp.
Every yr in texas we have the texas bash. its a huge show with j-bodys, delta bodys and kappas. i took 3rd place mild in the deltas last yr so my goal is to get 1st as well as knocking out alotta cars on the track. im shooting for about 300-350whp on stock motor for the next bash (possibly already there )
i bought this turbo kit on a whim because i got swindled by jbp on their cams and lifters so i saved some money and got a refund and scooped up a gt30r turbo kit for 1350 shipped on css...steal of a freakin lifetime.
included was
gt3076 turbo
3" charge piping.
log style manifold
3" dp
tial 38 mm wastegate
oil lines and some fittings
intercooler
lsj 60# injectors
stuff i added to the kit:
type-s bov (temporary)-probably pretty loud
Glowshift boost and volt gauges (7 color)
Innovate db blue lc-1 wideband
3 pod a pillar
Trifecta tune
sold the lsj injectors and got 2.4 specific injectors
pics of the original stuff..
Gauges
due to install fail and BAD direction and help from friends. the gt30 was killed. long story short. do not use teflon tape ANYWHERE near the oil feed line. thinking about it pisses me off cuz the gt30 is a beautiful turbo and would've gotten me to my goal EASILY.
some install pics from the tear down and install day august 14th and 15th. 2 weeks after purchase of the kit.
shows u how my piping was routed..because of how big that crap is i had to lose my driver's side fog light..
i lurked the forums and got a new t3 t4 garrett 50 trim to replace it.. and at 7 psi with this turbo ive been able to kill
-2006 cobalt ss 2.4 auto supercharged w/ full bolt ons and stock pulley. full mounts
-2006 ion redline, 2.8 pulley, full bollt ons, dual pass and dual heat exhchangers, as well as full mounts
-2008 g8 gt, intake, and underdrive pulley
so im pretty happy with it.. here's wut it looks like
sooo to sum this up..
I actually have more mods to install and theyre goin in on friday
-2.5" powdercoated black with beaded edge charge piping
-ci motorsports manual boost controller
-autolite iridium spark plugs
-vacuum block
-new fuel filter
-custom dump tube
on friday im getting my piping installed and welded so that i no longer need all of the couplers. and to clean up the bay a bunch and prevent poppage of the piping. the shop is also installing my boost controller, and making me a custom dump tube, as well as installing my new fuel filter (just hit 34k) if the vacuum block comes in on time ill have them put that in as well and ill do the spark plugs on my own later most likely.
dyno day is slated for next saturday. i was hoping for around 275 whp, but i was told i should be in the 300 range. if i am good, if i get 275 or so id be fine with that. technically 12psi with this turbo should get me 3xx so if i dont get it i may have a problem on my hands. vince from trifecta has helped me out alot with the tuning so im confident with his refining of my tune over the course of next week before the dyno day i should be able to hit 3xx. im still on my stock clutch but as some of u know i got a new set of wheels and as soon as i sell my current ones im buying my exedy stg2 clutch.
included was
gt3076 turbo
3" charge piping.
log style manifold
3" dp
intercooler
lsj 60# injectors
3 pod a pillar
Trifecta tune
Gauges
-vacuum block
-new fuel filter
-custom dump tube
