Brake position sensor
302mustang42
Hey guys!
I'm new here, stopping by for a technical question. I have a 2008 Cobalt LT sedan that has the brake lights staying on all the time. When you depress the brake pedal slightly, the lights go out, and then come back on around 1/2 to 2/3 press on the pedal.
I have 2 questions.
1. Why do all the parts stores insist that I don't have a pedal position sensor (clearly I do, I replaced it.) but instead a stoplight switch? I had to find one online.
2. Since I already said I replaced it, what is the next step in the chain? Does anyone have access to a wiring diagram for that circuit? Turn signals, 4-ways function properly. Shift interlock does not release until pedal is actually pushed and the lights come back on.
Thanks for any help!
Sounds like a wiring short somewhere. It's worth the $150 to buy the GM service books.
big gear head
I had to replace the brake booster on mine. The brake lights would stay on and the cruise control wouldn't work. It only happened if I was running 50 MPH or more and then lightly applied the brakes. I replaced the brake light switch 3 times and it didn't fix it. Replacing the brake booster did fix it.
Bqueen84
