280k mcd led headlights almost complete
that's a bit big i prefer flush mount switches makes it look so much cleaner and sometimes it may even look stock
hey thanks for letting me know. Radio shack has this one you posted so im going to go pick it up. Make it look close to stock. Anybody know the best way to wire up the switch.
same switch i got for my foglights
on mine there is 3 prongs that are coming off of it
prong 1 goes to a fuse tap
prong 2 goes to the fogs ( in your case the LED's)
and 3rd prong goes to a ground ( i found a nice ground under the dash where the ebrake is)
CobaltCpe
Dallas
hey,
I would like to use a mini-add-in-circuit like the one below. I see #20 for sunroof is there and i don't have a sunroof so thinking i could use that or even any of the empty slots. What size fuse should i use for the mini-add-in-circuit.
outtamymind
Calgary, Alberta
well whats the amp rating per led. should only be .5 of an amp or less. so if you got 10 led's in each i wouldn't go higher then a 10amp fuse. try out a 7.5 first though
CobaltCpe
Dallas
nah i have 12 leds in each headlight x 2 = 24. They are rated at 0.5 watts each. So that would be a 12 watts which then needs to be converted to amps.
nah i have 12 leds in each headlight x 2 = 24. They are rated at .5 amps.
So you need a 15amp fuse. Or that's my guess. If it blows that try a 20. Etc. But if you get to 30 and are still blowing em something is wrong.
CobaltCpe
Dallas
ok let me keep on checking and find out.
CobaltCpe
Dallas
Amps = Watts/Volts
so for example if each led is 0.5 watt each x 24 (12 leds in each headlight) = 12 watts/12 volt (car) = 1 amp
So can i just remove the sunroof 15 fuse, replace that with a blown fuse and add a 2 amp fuse for the leds. I think this would work with the add-a-fuse.
Bqueen84
