2.2L LAP/L61 S/C Technical Build Thread
Option B is the most important part of the equation to make sure you get the air out of the aftercooler system. That means a restricted line from the top of the (oem) heat exchanger. The stock T bottle is hopelessly ineffective on the LSJ aftercooler system.
The next is dual pass. Thats a little more involved, and requires great care re and re the end plate, swapping the laminova cores end for end, and replumbing the hoses.
My preference is to use the Saturn coolant bottle with decent brackets; you can buy the dual pass end plate where ever you wish. you need, and the "T"'s and "Y"'s are important...P.S GM have good "how to" instructions I think they are on this site....
But also I would buy a GNR style racing griffin h/e before I spent money on dual pass, if money was tight. So you would have option B , four pass and a better h/e, double the core thickness and tanks, in the stock location...
lnf front strut bar
picture.php
tune, wide band w/ air fuel ratio thingy, and a couple bolts
i need fe5 bushings and bushing mount clamps
ff_drift_lol
long island, new york
jeez so you're right there. the uego is an all in one wideband controller and gauge. goes for about 200 on ottp or your preferred vendor. tuning, i can say stay away from boxed tunes. i'm sure you know this stuff, just putting it out there. other than that you're basically done. i can't wait to see some numbers.
ls2 edit is out, nothing around my parts capable of doing it, its an 06 l61 so HPtuners refuse to do anything with it, all i got is trifecta
i forgot i need a heat exchanger, someone local is selling the ottp one so i think ill grab it
Fwagile
