Water leak by A peeler- front passenger side door
jack
I have had a water leak for the last three months coming the a peeler on the passager side door when it rains. I have cleaned out the vent under the wheel well, cleaned out the drain hole by it. replaced the plastic that connects the windshield to the hood by the front panel. I have had no water link using my A/C unit. Any suggestion or insight is helpful to solve this problem.
---------- Post added at 01:50 PM ---------- Previous post was at 01:38 PM ----------
My Cobalt has sun roof on it. Could the water leak be coming from there? If so what can I do to fix it?
wehan
I had a similar issue, turned out that water was getting in through a gap left by an aftermarket speaker install. Also, Check the drain holes in the door.
Sunroof drain is either clogged or disconnected. Check both ends of the drain tube.
