Turbo 2.2 using other factory kits
Jn2
2003+ Saab 9-3 set up:
-Saab 9-3 turbo manifold
-2003+ Saab turbocharger(both low and high pressure turbo will work)
-turbocharger oil/water lines(inc. banjo bolts)
-Saab turbocharger cold charge piping(for going under the engine)
-universal intercooler kit
-universal intercooler(28"x6"x2.5" fits perfectly behind out bumpers)
-custom downpipe
-42lbs injectors
-injector harness(repin to stock)
-trifecta tune(all years), Ls2edit(07+)
-MAF pipe(i recommend buying a bung from OTTP and having it welded on your piping or call ZZP and have them make u a MAF pipe)
-custom intake or run a mesh filter
-gaskets for turbo, manifold, and downpipe
-wideband kit
optional/recommended:
-aftermarket blow off valve(the turbo has a built in one)
-2.5" catback exhaust
-PnP turbine housing
-high pressure turbo from the b207r saab engine
-2.4 intake manifold/Saab 9-3 intake manifold
-LNF intake manifold strongly recommended
***sensor placement***
-MAF: goes after the intercooler, before the throttle body, keep 6-12" from throttle body
-Blow off valve: after the turbo, before the intercooler
LNF Cobalt turbo set up:
-turbo manifold
-turbocharger
-oil/water lines
-o2 housing
-LNF intake
-downpipe
-hot charge pipes
-intercooler
-custom cold charge piping
-60lbs injectors(may be able to pull of 42's, but better safe than sorry)
-all exhaust gaskets for the LNF turbo manifold, turbo, o2housing, and downpipe
-wideband kit
-aftermarket charge piping W/bov flange on hot pipes, MAF bung on cold)
-aftermarket downpipe
-aftermarket intercooler
-3" catback exhaust
-aftermarket intake(W/NO maf BUNG)
-aftermarket intake manifold
Oil feed line=blue
Oil drain=red
Jn2
added more pics...and will ad more when i get home, i have a pic of the LNF parts off a car saved on my machine from when someone over on .net was selling it
Jn2
the saab setup would probably run you in the area of 1000-1500 depending where you have your downpipe made, and on who does your tuning...the lnf kit could be more pricy since those are newer parts not commonly found at junkyards
case310
