Stero wiring Diagrams
Tom
Houston TX
Stereo wiring Diagrams 05-07 LS-->SS/G5-->GT
2005-2007 Cobalt LS/Pontiac G5 Base model
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power. The accessory turn-on and amplifier turn-on are controlled by the class 2 serial network.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
2005-2007 Chevrolet Cobalt Supercharged/Pontiac G5 GT with Pioneer Audio
Car Radio Illumination Wire: N/A
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Factory amplifier is located behind the driver side of the dash (near the firewall).
Left Front Speaker Negative Wire (-): Dark Green
Right Front Speaker Positive Wire (+): Light Green/White
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Brown/White
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Negative Wire (-): Tan
2007 Saturn Ion 1 Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
jmarie
Maryland
this is actually helpful.. i might have to check my speaker wire myself instead of not haing my car for X amount of time bc it takes them "all day" to check it out
delinquentJACK
Canada
I need help. Wiring a JVC KD-R670 in my brother's '07 Cobalt LT. Wanted to keep RAP so I hard wired the PAC harness and all wires other than radio illumination wire, can't figure out where to connect the illumination wire from the deck. I've gone over everything a dozen times, checked resistance on speaker wires to make sure nothing is shorting, and wired everything according to the pinout for the PAC harness and wiring diagram for this car. I've tried the grey illumination wire in the Cobalt pinout and I get nothing. That wire tests no power with key off and 14.2 volts with car running. The only thing I can think of is something is fried in the deck (already had it turned on showing miswiring error).
I'm at the point of rage because I can't get this stupid thing to work. Someone please help.
Does the illumination wire work when you test it against whatever it's looking for? I believe it's supposed to get voltage, but you'd have to check the manual for that. It's a surefire way to figure out if it's broken.
