Purge Valve Solonoid line
Buck Sr
Ohio
Does anybody know if the line going to the purge valve solenoid (the one with 2 little white clips) should be tight? How would you take that end off?
New gas cap and fuel tank pressure sensor and am still receiving the PO455 code and its driving me crazy.
The purge valve solenoid has been replaced also.
Thanks for anybodys help.
jeffsPSEMadness
Rochester
Push both tabs with your finger and pull it off. It's not right but should be snug do to the o ring making it seal. Make sure you slide it all the way on. If you changed all of that and still having problems you should have a smoke test done.
Sent from my iPhone using Tapatalk
Buck Sr
Ohio
Thanks for your help again.
Plea
