how to change starter
ionit3
o town fl
originally written by Elvis C
This is all done without any jackstand or anything you can do this without jacking the car up in the air.
I currently have no pics but I'll go through each step perfectly.
EVERYTHING DONE IS WITH THE BATTERY UNHOOKED
1) Remove your throttle body + throttle body cable (it pulls off from the bottom, its a metal ball.)
2) Remove your intake manifold (5 10mm Bolts + 2 10mm Nuts)
3) Make sure to take off the evap line (press the clip together and pull it out)
4) Take off break booster line (lift the white clip with either a flat head screwdriver) and it'll slide right out
5) unplug the map sensor connector
6) Unplug your injector wiring harness (it's near the bottom left (passenger) side) just push in the clip and pull them apart
7) once the intake manifold is removed you'll see a long cylinder with 3 prongs .l...that's the starter
8) remove 1 13MM bolt holding 2 Positive wires (the bigger one goes stright to the battery)
9) Take off 1 10mm bolt which holds the switched 12v for the starter
10) Remove the bottom 15mm bolt
11) Remove upper 15mm bolt
12) Pull starter out
To put it back together just reverse these steps. but MAKE SURE TO PUT ON THE 12V+ ON FIRST OR ELSE YOU'LL HAVE A SHORT AND YOU WILL BLOW YOUR STARTER
Staff online
