engine swap years ????????
stapletonb08
I have a 2006 manual 5 speed cobalt NON supercharged, i need to buy another engine for it i was told that you can only interchange engines within 05-06, 07-09, 2010- present. My question is do i really need to buy a 05 or 06 engine to drop in? or can will it be just as easy to drop a 09 in? if so what parts do i need to make everything work?
[wrong info removed]
Why do you need a new motor? Could rebuild your current one.
stapletonb08
So your saying the supercharged 2.0 and the normal 2.2 can interchange with no mods? im not really interested in the supercharged engine cause its just a work car.but if i can find one cheep i would consider it. I want just to engine swap instead of fixing my old engine.A tooth on one of the sprokets broke causing it to jump a tooth and now its out of time. valves are probably bent and much more.
---------- Post added at 05:25 PM ---------- Previous post was at 05:23 PM ----------
my car does not have a supercharged engine by the way lol it has the turd.
Bass_Waves
Then you should he fine dropping in a reg 2.2 from the same bracket year as yours
stapletonb08
ok so they changed the barackets through the years. ok ill just go with a 05-06 then . thanks!
Oops, sorry I misread. You can only use an 05-06 L61 2.2 motor.
In 07 they added SAI, and after that changed to a VVT head in 08+.
Unless yours is the 2.4 LE5 motor, then you need that one.
Bass_Waves
He is most likely getting the L61. Since he has a 2006
Jaydom2415
I got an o7 cobalt. Blown mtr is base model with 2.2l. Will the 2.4l swap right in if. So how involved is that conversion
It won't. You need a new ecu, extra sensors, there's other stuff too.
