2.4 Performance Mods
Intake: The stock air box is highly restrictive. Freeing this up would provide more air for combustion and increase power output
  • Cold Air Intake
    • Injen >>
    • AEM
    • Rebel Autoworks (RAW)
    • Advanced JDM >>
  • Short Ram Intake
    • K&N Typhoon 2.4 specific >>
    • GM Performance Parts >>
    • AEM
    • Z-spec/RSM Racing >>
    • Weapon R >>
    • Air box mod INFO
  • Intake Manifold
    • Hahn Racecraft INFO
    • Vulcan Turbo >>
    • Kinsler Fuel Injection (optional upper rail kit) >>
Exhaust: The less restrictive an exhaust setup is, the more power will free up from an engine. Our 2.4 stock exhaust system is decent (has 2.5" piping), but it is restricted by the header, cat (in the downpipe), and the exhaust section from rear wheel back (which becomes 2.25" piping and has a restrictive muffler)
  • Header (Exhaust manifold)
    • Long Tube (high-end gain)
      • Weapon R Race Header (with downpipe, no cat)
      • JBP Vortex Header >>
    • Mid-length (mid gain)
      • ZZP Midlength Combo (with downpipe, optional cat) >>
      • SLP Combo (with downpipe, cat)
      • Vibrant Header Combo (with downpipe, cat)
      • OBX
      • Pacesetter Header
      • Clear Image Automotive Header >>
      • CTI Race header (optional cat) >>
    • Shorty (low-end gain)
      • CA Header V1 (not produced anymore)
      • CA Header V2
      • Shiny-Hiney (identical to CA V1) >>
      • DC Header
      • Hahn Racecraft
      • Stock Extruded and Honed
      • BADMAB Industries >>
      • ZZP Header
    • Turbo (for turbo applications only)
      • Vulcan Turbo Downward Manifold
      • Vulcan Turbo Equal Length Manifold
  • Downpipe
    • XTC Downpipe (optional cat, 2.5" or 3")
    • ZZP Downpipe (optional cat, 2.5" or 3")
    • Stock LSJ Downpipe w/ cat INFO (requires some modification for the Auto Trans.)
    • Clear Image Automotive Downpipe (optional cat) >>
    • JBP Vortex 3" Downpipe >>
    • CTI 3" downpipe (optional cat) >>
  • Catback
Engine: (requires tuning)
  • Forced Induction
    • LSJ Supercharger Kit swap INFO
    • Hahn Turbo Kit
    • ZZ Performance Turbo Kit INFO
    • ZZ Performance Supercharger Kit >>
    • Speed Mafia Procharger Kit (currently only available for Ion) PIC
    • Custom turbo kit INFO
  • Camshaft
    • JBP Tri flow camshaft >>
    • Custom regrind
  • Nitrous
    • NOS
    • Nitrous Express
    • Zex
    • Holly
    • Vemon
    • DynoTune
  • Throttle Body
    • Throttle Body port/swap
    • Individual Throttle Body kits
    • ZZ Performance Throttlebody adapter plate >>
  • Injectors
    • LSJ Injectors, or Stage 2 Injectors
    • #33 Injectors >>
    • #39 Injectors >>
    • Siemens #60 Injectors >>
    • Cobalt-Addiction #80 Injectors
  • Cylinder Heads
    • JBP Cylinder Head Kits >>
    • Custom port and polish INFO
  • Pistons
    • Wiseco
  • Connecting Rods
    • Flatlander Racing
    • Pauter
    • CARRILLO H-Beam >>
    • CARRILLO Super A-Beam >>
  • Electrical
    • Jet Performance Chip MAF sensor
  • Crate Engines
    • JBP LE5 Performance crate engines >>
Pulley
  • Crank
    • MRZ Performance (either smaller or OEM size) INFO
    • MD Pulleys
    • JBP >>
    • Z-spec
    • Cobalt-Addiction >>
  • Alternator
    • MRZ Performance INFO
    • MD Pulleys
Transmission:
  • Manual
    • Short Throw Shift kits
      • TWM Short Shift Kit
      • B&M Short Throw Shifter
      • Ark Performance
      • Any STS kit for the Getrag Transmission in some 2.4L and all Ecotec equipped Cavaliers will fit the 2.4L manual transmission INFO (Some may require slight modification to fit properly)
    • Clutch Kits
      • Exedy Racing
      • SPEC
      • Competition Clutch
    • Flywheels
      • Fidanza
      • SPEC
      • ACT
    • LSD (Limited Slip Differential)
      • Quaife
    • Miscellaneous
      • ZZP master cylinder clutch rod >>
      • N2MB Racing WOT Box INFO
  • Automatic
    • B&M Shift Plus INFO (for late 06+, wiring is a bit different)
    • Transmission Tune
      • Quaife
Tuning: Our stock engine tune is rather conservative. Tuning parameters like power enrichment delay, air to fuel ratio, and spark timing will result in decent horsepower gains. Tuning after installing bolt ons (intake and exhaust) will further bring out the potentials of those modifications
  • Tuning Equipment INFO
    • Hptuners >> (doesn't support 2008 ECM yet)
    • EFI Live >> (doesn't support 2008 ECM yet)
    • LS2-Edit >>
    • Trifecta Performance Tuning INFO
    • AEM F/IC >>
  • Canned Tune
    • Vector Motorsport >>
    • Jet Performance Chip INFO
    • Westers >>
Legend:
>>= Link to product
Videoclip= video
PIC= Picture
INFO= Additional information on product
OK I think I got everything that wasn't added from the last thread. If you see something missing or a link that doesn't work just post it up and I'll add it. Also if you have a video clip or picture of your exhaust that isn't already up please post the link and I'll add it.
nnnn
    • LS2-Edit >>
    • AEM F/IC >>
  • Canned Tune
    • Westers >>
Legend:
>>= Link to product
Videoclip= video
PIC= Picture
