I have an 06 Cobalt Eco 2.2 L. I have problems intermittently with steering. It will become hard (enter manual steering) to steer randomly. I have read some things about the electric power steering being a piece of crap on these things and would like to know if anyone has fixed this with just a motor swap on the column? Any advice is greatly received.
Additionally, the traction control light comes on sometimes and I haven't been able to get the code read, but reading up on it says that it might be a timing issue (WTF????). I don't know how that has anything to do with traction but ok. Figuring that I'd check the spark plugs and wires first I did some research to cover all bases. I also found that the timing chain tensioner is a huge problem with these things as well. Finally, last night after changing the oil I went to start it and it sounded like it was about to die on the low end of the rpm scales. It actually stalled once. On the drive home it seemed to get better. Hints, advice, etc is appreciated, but I was thinking to change the chain tensioner, plugs and wires to cover all bases. thanks.
